1. jpmoore
  3. Tuesday, 06 December 2022
I have recently upgraded a site from J3 to the latest version of J4.
I have tried layla, sophia and natalie templates, but with all I encounter an issue where white space is showing to the right hand side of the screen. It doesnt appear when scrolled down (and sticky menu is at top), but only when scrolled right to the top.
Is there a solution for it?
Many thanks
Jonathan
A link to the page will be necessary here...
(Any other explanations about the structure of the site)
Unfortunately, the site is currently offline, as I want it to look perfect (im making other changes) before making it live again.
I will forward my message - along with access information - in a support message to Ciaran.
Jonathan
Hi Jonathan
May I suggest sending the URL to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Thank you Jonathan
The reason for the whitespace is due to some of your menu dropdowns are breaking out beyond your viewport In particular the dropdown to your History & Records dropdown. To reduce the width of this dropdown, could you try replacing the columns-4 class with columns-3.
Hello Ciaran
Thanks for this - which partially fixes the issue. One menu is four columns wide, but as its torwards the right hand side of the main menu, it still goes off to the right (left from the menu option).
This i because the dropdown menu is right-aligned under the menu. Can it be left-aligned so that it doesn't go off page ?
Jonathan
I am looking for this approach (left-alignment) on sophia, natalie and layla. Is it possible?
Replace 777 with the parent menu item ID of your choice (right column in menu manager)
.hornav .item-777 > ul {
left: auto !important;
right: 0;
Hello Ciaran
Thank you so much for this code. It has made such a difference.
To make the site perfect, I am looking to set the width of the sub-menus. Each sub-menu is either 2 or 3 columns wide. I saw code such as the code below, but this hasn't had the desired impact
.hornav .item-511 ul {
min-width: 270px;
A screenshot of the issue is attached:
Kind Regards
Jonathan
Hi Jonathan
Your CSS will only apply to a dropdown whose parent menu item ID is 511. Is this correct and intended? Is the CSS getting applied but not the desired result or simply not getting applied at all?
Yes, the above was applied, but didn't work.
Since then, i've implemented the following CSS:
.hornav .columns-2 + ul {
width: 600px;
.hornav .columns-3 + ul {
width: 800px;
.hornav .columns-4 + ul {
width: 900px;
.hornav .item-511 > ul {
right: 0;
.hornav .item-568 > ul {
right: 0;
.hornav .item-2866 > ul {
right: 0;
.hornav .item-3361 > ul {
right: 0;
However:
1) is it possible to set a minimum sub-menu width at parent item level?
2) is it possible to (as per image showing Election Results sub-menu) to have its sub-menu on the left?
3) the 'heritage' menu, despite being set-up as columns-2 or columns-3 is not displaying correctly. Can you look into it?
Jonathan
Hi Jonathan
Thank you for the update.
Replace 777 with your parent item ID.
min-width: 400px;
2. / 3. On these items, get back to us once your site is available online and we will look into a possible solution.
I notice requested details have already been sent. :)
.hornav .item-590:hover ul, .hornav .item-590 ul {
left: -230px !important;
width: 230px;
2. To amend try also adding the following (edit to taste)...
max-height: 440px;
