1. sammy1979
  3. Tuesday, 27 February 2018
Good morning, I bought the template j51_harmony.
In the "blog" view the introduction image is located after the title (http://www.serconmarketing.it/comunicare/) but in the single article view the image is positioned before the title (http://www.serconmarketing.it/comunicare/index.php/zoom/8-questo-carnevale-sembra-una-favola)...
I want that the title is always after the image. How can I do this? What file of template I have to change?
Thank you for the answer
  1. http://www.serconmarketing.it/comunicare/
  2. http://www.serconmarketing.it/comunicare/index.php/zoom/8-questo-carnevale-sembra-una-favola
Hi Sammy
To amend try adding the following to the Custom CSS field of your template settings...
.blog-featured .item {
display: flex;
flex-direction: column;
.blog-featured .item-image {
order: -1;
I added also this code and it works:
.blog-featured .article-info {
display: flex;
order: -1;
What do you think about?
Hi Sammy
Yes that is fine. You could possibly remove the display:flex; as it will be inherited from it's parent.
Thank you so much!
with this solutions it works, but if I want to leave the informations about category, author, etc.. above the image, like in the article view? It's possible? Thanks
