1. sammy1979
  3. Tuesday, 27 February 2018
Good morning, I bought the template j51_harmony.
In the "blog" view the introduction image is located after the title (http://www.serconmarketing.it/comunicare/) but in the single article view the image is positioned before the title (http://www.serconmarketing.it/comunicare/index.php/zoom/8-questo-carnevale-sembra-una-favola)...
I want that the title is always after the image. How can I do this? What file of template I have to change?
Thank you for the answer
  1. http://www.serconmarketing.it/comunicare/
  2. http://www.serconmarketing.it/comunicare/index.php/zoom/8-questo-carnevale-sembra-una-favola
Thank you so much!
Hi Sammy
Yes that is fine. You could possibly remove the display:flex; as it will be inherited from it's parent.
I added also this code and it works:
.blog-featured .article-info {
display: flex;
order: -1;
What do you think about?
with this solutions it works, but if I want to leave the informations about category, author, etc.. above the image, like in the article view? It's possible? Thanks
Hi Sammy
To amend try adding the following to the Custom CSS field of your template settings...
.blog-featured .item {
display: flex;
flex-direction: column;
.blog-featured .item-image {
order: -1;
