1. Siracher
  3. Wednesday, 19 February 2014
Hi, the host of my server just updated to php 5.4. Now I get this error message on the pages using the ThumbsGallery:
Warning: Creating default object from empty value in /home/pizolimm/www/rietcenter/modules/mod_j51thumbsgallery/helper.php on line 24
I managed to ged rid of it reducing the php alert level. But of course wont to avoid the error at first hand.
Is there an update planed to fix this?
thanks
May I ask what version of Joomla you are using?
sure, I have installed there version 2.5.18
Could you try installing the following updated version of our ThumbsGallery module which should resolve this issue...
https://dl.dropboxusercontent.com/u/69136519/mod_j51thumbsgallery25.zip
  3. # 3
thanks a lot! works fine now (after clearing cache) :laugh:
  3. # 4
dear Ciaran,
i installed your dropbox version of ThumbsGallery25 mentioned above.
Unfortunately i still get the error:
Creating default object from empty value in .../joomla/modules/mod_j51thumbsgallery/helper.php on line 25
using Joomla 2.5.24 on php5.4.4-14+deb7u14
any idea!
  3. # 5
  3. # 6
