1. webknecht
  4. Friday, 21 January 2022
I tried to customize the Layla-Template for Joomla 4 by changing the nexus.css.
To do so in the past I was able to make small changes using the Joomla 3 Templates.
But now I have the feeling that nothing happens in the frontend changing the nexus.css
Maybe are there other css-files I had to change????
Thanks in advance
Jürgen
Hi Jürgen
If you are loading minified CSS, then you would need to edit the nexus.min.css. In general thou I would suggest adding your custom CSS to the Custom CSS field of your template settings or creating a custom.css as detailed in the same panel. This will ensure your CSS gets added last in the cascade.
of course I used the custom.css to make the changes.
Today I made an side update from Joomla3 to Joomla 4.06 using the J51 Ashley Template for Joomla 3 and it was a great surprise it works fine!!!!!
Jürgen
Hi Jürgen
Some of our earlier more basic templates may install without issue however I suspect some Joomla views will likely render incorrectly as our Ashley template is based on Bootstrap 2 and Joomla 4 is based on Bootstrap 4. Admittedly I havent tested it but if it works, that is great :) Have you tried some of the more advanced Joomla views (eg. frontend editing?).
Regarding your CSS, would you have a URL to an example of thes issue?
the css issue is solved. I used the custom.css at your recommandation.
Will there be Joomla 4 versions for the Ashley and the Renovate Templates, which are my favourites??
For the look of the Ashley template I adapted the new Layla 4 Template changing the custom.css.
Of course I only want to use Joomla 4 compatible templates in the future. The Ashley 3 template seems to have been a coincidence as well, as I tested another site where it didn't work.
Jürgen
Hi Jürgen
Yes we intend to create Joomla 4 versions of both the Ashley and Renovate template although I would be unable to give you an exact date on when the updates will be available.
this is no problem, because some needed components are also not available in Joomla 4 compatible versions.
The updates from sites to Joomla 4 is always a big surprise what happens.
Jürgen
