I use the J51_MonoChrome template with Joomla 2.5
I have problem with the hornnav menu. I've tag "views all links" to yes, and put moomenu in the "menu tag ID", but my dropdown menu doesn't work.
Any idea ?
Sorry for my english, i'm french.
Thanks a lot
- guyleblanc
- Friday, 25 January 2013
http://volvo.testmediom.com/
I can create you a user, if necessary.
Thnaks a lot for your help !
Guy
Guy
A strange one.. it appears all your SEF links are linking to the same page. Are you having the same issue if you disable SEF URLs?
Sorry, but I'm not sure about what you mean by SEF URLs?
I've disable all other menu...
Still have the problem.
Thanks for your help again..
Guy
Guy
Ok, I change the type link of the parent, for "separator" and it's working...
But I have this error in IE now.
Détails de l’erreur de la page Web
Agent utilisateur : Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB7.4; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Horodateur : Fri, 25 Jan 2013 15:45:35 UTC
Message : Object doesn't support this property or method
Ligne : 94
Caractère : 25
Code : 0
URI : http://volvo.testmediom.com/templates/j51_monochrome/js/dropdown.js
Ligne : 514
Caractère : 25
Code : 0
URI : http://volvo.testmediom.com/media/system/js/mootools-core.js
Thanks...
Ligne : 94
Caractère : 25
Code : 0
Ligne : 514
Caractère : 25
Code : 0
Thanks...
Hi Guy
If you could send us temporary administration access to your Joomla installation to info@joomla51.com we can examine this issue further.
Thanks for your help.
But I still got the error, in IE 8...
Do you know why ?
Thanks.
Guy
Do you know why ?
Thanks.
Guy
Try removing the following from your templates index.php (../templates/j51_monochrome/index.php)..
<script type="text/javascript" src="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/js/dropdown.js" charset="utf-8"></script>
window.addEvent('domready', function() {
var myMenu = new MenuMatic();
</script>Ciarán
- # 9
