1. guyleblanc
  3. Friday, 25 January 2013
I use the J51_MonoChrome template with Joomla 2.5
I have problem with the hornnav menu. I've tag "views all links" to yes, and put moomenu in the "menu tag ID", but my dropdown menu doesn't work.
Any idea ?
Sorry for my english, i'm french.
Thanks a lot
That's working!
You're the best!
Thanks a lot... Great support!
Have a good day!
Try removing the following from your templates index.php (../templates/j51_monochrome/index.php)..
<script type="text/javascript" src="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/js/dropdown.js" charset="utf-8"></script>
window.addEvent('domready', function() {
var myMenu = new MenuMatic();
</script>
Thanks for your help.
But I still got the error, in IE 8...
Do you know why ?
Thanks.
Guy
I've just sent you an e-mail...
Thanks again !
Guy
Hi Guy
If you could send us temporary administration access to your Joomla installation to [email protected] we can examine this issue further.
Ok, I change the type link of the parent, for "separator" and it's working...
But I have this error in IE now.
Détails de l’erreur de la page Web
Agent utilisateur : Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB7.4; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Horodateur : Fri, 25 Jan 2013 15:45:35 UTC
Message : Object doesn't support this property or method
Ligne : 94
Caractère : 25
Code : 0
URI : http://volvo.testmediom.com/templates/j51_monochrome/js/dropdown.js
Ligne : 514
Caractère : 25
Code : 0
URI : http://volvo.testmediom.com/media/system/js/mootools-core.js
Thanks...
Sorry, but I'm not sure about what you mean by SEF URLs?
I've disable all other menu...
Still have the problem.
Thanks for your help again..
Guy
A strange one.. it appears all your SEF links are linking to the same page. Are you having the same issue if you disable SEF URLs?
I can create you a user, if necessary.
Thnaks a lot for your help !
Guy
