1. arani
  3. Wednesday, 23 July 2014
I just bought the catalyst template, and neither the gallery work nor does the autson slide show feature work.
I have added multiple images for the slide show and configured as per your pdf document that comes with the installations files. and yet after display the first image, nothing happens.
On the issue of the gallery, it does not show up at all.
On a different note, how do you add more menus and add video content onto this template
Looking forward to your response
Cheers
Fopr details on setting up menus in Joomla may I suggest the following articles..
http://docs.joomla.org/J3.x:Adding_a_new_menu
http://docs.joomla.org/Adding_a_new_menu_item
Hi Ciarán
It's a bit difficult to give you access, as it's part of my company intranet.
Any other way this can be looked at.
Sorry to say the only way we can look at this is via administration access on a hosted Joomla installation.
May I ask what version of Joomla you are using?
  3. # 3
My Joomla version is 3.3.1
  3. # 4
Please ensure you have jQuery disabled via the slideshow modules parameters as this is already loaded by Joomla.
  3. # 5
jQuery is disabled. Anything else that might be the issue.
  3. # 6
Check that there is not installed extension conflicting with your slideshow module. Firstly navigate to your Module Manager (Extensions -> Module Manager) and disable each module displayed on the same page as your slideshow until you find the conflicting module. If the issue is present on some pages but not on others then this is mostly the case. Failing that, disable each installed plugin (Extensions -> Plugin Manager) until you find a conflicting plugin.
Note: To disable 3rd party plugins navigate to your Plugin Manager (Extensions -> Plugin Manager). Sort your plugins by ID in decending order. 3rd party (non Joomla) plugins will be listed first and will have an ID number significantly higher than your Joomla plugins which will usually be in the 400 to 500 ID range.
  3. # 7
