Dear All
Thanks for your support so far, it would have been difficult without it to make progress
My site is almost finishing but a strange thing had happened.
I followed the same format as Joomla presents when you install first time and add documents to appear on homepage. Everything was fine till suddenly I notice the word "Subcategorie" has appeared on the bottom of the page.
I make note of every step or change so I can revert it if necessary but this one I did not know how it came it.
I tried Firebug and Inspect element in Firefox and Chrome to locate and remove it from the code but could not find the actual file. I have checked and rechecked all the settings but not luck so far,
website address: http://www.pcwebsystems.co.uk
would anyone be able to assist in this matter
If problem solved, I would appreciate if the explanation is given so if it occurs again I would not bother anyone,
Kind regards
Sadegh
