I expected the J51 Stella4J template to be downwards compatible to Joomla!3. That seems not to be the case. The template works with Joomla!4.
My experience till now is first update the website to joomla!4, and delete Stella 3J before uploading Stella 4J.
In my experience, after updating to Joomla 4, the template folder must be deleted or renamed:
from templates/j51_stella
rename to templates/j51_stella_old
Now repeat the installation of the template. If there is a custom.css and/or a favicon.ico in the old template folder, these two files can be copied over from the templates/j51_stella_old folder. Finally the template settings must be entered again manually consulting the previous template.
This worked for me.
The J51 templates are unfortunately not really immediately usable, after the update to the Joomla 4 version.
