1. webknecht
  4. Thursday, 11 February 2016
used the vitality template updating a site where the grafik template works fine.
There seems to be some different css settings. To describe the problem attached you find the same site using grafik and vitality template.
The various thumbs should appear as the grafik template.
Thanks in advance!
Juergen
Hi Juergen
Would you have a URL to an example of your Vitality screenshot?
Thank you Juergen
To resolve try removing the following from your templates nexus.css (../templates/j51_vitality/css/nexus.css - line1227)...
#container_main .wrapper960 div {
box-sizing: border-box;
overflow: visible;
thanks a lot for your help.
Now all works fine!!
Juergen
Great!
Thank you for the update.
now another small problem appears using the vitality template, please take a look at
http://www.wienhoefer-immobilien.de/content/index.php/immobilien/ses/exposee-3-haus-in-drage-kaufen.html
There you see a slider showing detailed pictures. If klicking the forward button to change the current picture first this picture disappears. Also using the sliding resp. carousel pictures first disappear.
I tried it using another template f.e. the j51 ashley template, all works fine.
Maybe there is a small solution for this issue??
Thanks in advance
Juergen
Hi Juergen
I readded the removed code at line 1227 follows and all seems to works fine.
Juergen
Excellent... thank you for the update!)
