1. TorstenL
  4. Monday, 29 August 2016
Hi there,
I´ve added a new icon to the social media icons but can´t change the hover colour, tried it with a few browsers (Edge, Firefox, Internet Explorer), the only colour I can choose is black:
[img size=400]http://imgur.com/a/6LiXv[/img]
Second thing, where can I change the height of the header bar:
[img size=400]http://imgur.com/a/2l5SI[/img]
Many thanks
Torsten
Hi Torsten
1. Would you have a URL to an example of this issue? There is currently an issue with Joomla regarding the color field in a repeatable form type. This issue will be amended in the next Joomla update. In the mean time you can set the color using CSS.
2. To edit your header height try adding the following to the Custom CSS field of your templates parameters (edit to taste)....
#header {
height:240px;
Hi Ciarán,
1. Sure, here you go:
I´ve added the colour for the email icon to the nexus.css now.
2. Also added the code to the "Custom CSS field" and that´s working. But how can I turn off that "Magnifying Effect":
[img]http://imgur.com/a/gxaHE[/img]
Torsten
Hi Torsten
2. By default the header image background-size property is set to 'cover' which ensures the image fills this area on all screen sizes. To disable this you can add the following to the Custom CSS field of your templates parameters...
.vegas-slide, .vegas-slide-inner {
background-size: auto auto !important;
Hi Ciarán,
many thanks for the update. When I put in the suggested code, the image disappears.
Best regards
Torsten
Hi Torsten
Hi Ciarán,
email sent.
Best regards
Torsten
Thank you Torsten
We have amended your custom CSS to the following...
background-position: 50% 0% !important;
Many thanks, Ciarán, that is working now.
Cheers
Torsten
