please have a look at http://www.seminart.pixmess.at or the attached screenshots.
on the big pc screen the background pic on the home site is perfect, but on a mobile devices the pics are not rescaled, only a part of the pictures are shown.
Is there a possibility to rescale the pics?
Thank you , Marion
			- salinger
- Thursday, 05 May 2016
				Hi Marion
In your templates Custom CSS field you appear to have the following which is setting an image size across all screen sizes...
Removing this should resolve the issue.
.vegas-slide-inner {
    background-size: 1800px auto !important;
} Removing this should resolve the issue.
no it doesn't really help. I tried that before...there is just another part of the picture visible, not the whole picture.
thanks, marion
thanks, marion
				Hi Marion
Sorry to say, presuming I understand you correctly, there is no way to achieve exactly what you wish. The background header image will always fill the entire screen. This means that this image will be cropped either vertically or horizontally depending on the screen size and orientation. As all screen sizes are different there is no across the board solution.
				ok thats bad news, so I had to choose another solution...I installed the slidshow module which works exactly as I want it to have. but still there are 2 problems left...
1. see screenshot please. purple background should fill the complete width. no white space above picture.
2. pictures on all other sites (not the home site) are not resized correctly as on the slideshow module. please see second screenshot. the width is too small and there is too much space between picture and headline. I used pictures in an empty module.
I hope you can help again, thank you, marion
PS: upload screen shot does not work, I'll send it again by mail.
				Hi Marion
1. To amend try adding the following to the Custom CSS field of your templates parameters...
2. This appears to be caused by CSS coming from an 'acymailing' component...
You can try overruling this CSS with the following Custom CSS...
.showcase img {
    margin: 0 !important;
} 2. This appears to be caused by CSS coming from an 'acymailing' component...
img {
    margin-top: 20px;
    width: 40%;
} You can try overruling this CSS with the following Custom CSS...
img {
    max-width: 100%;
    width: auto;
} Ciarán
				Hi, Ciaran,
I found the problem and deleted the wrong code with 40% width...so problem solved, thanks a lot...
