1. revolion
  4. Wednesday, 09 July 2014
I have 2 pages on the site I am building that the drop down menu is not working on. It works on every other page, but not the 2 pages that I use a LightBox extension from Diginix Technologies. Cant seem to figure out the issue. Thank you for your help.
Trying to figure out if it is a Java Script issue.
Kindest Regards,
Jeremy
Hi Jeremy
Issues can arise if jQuery is loaded twice on a particular page. As jQuery is loaded by Joomla 3.x by default, as a rule you can disable jQuery in any extension you are using presuming the option is available. You could also consider installing 'jQuery Easy' (http://extensions.joomla.org/extensions/core-enhancements/performance/jquery-scripts/18327) which ensures only one copy of jQuery is loaded across your site.
Ciaran,
Thank you for your suggestion. Idid get the jQuery Easy extension, however not sure what to set or how to configure it to get the menu working again on those 2 pages. Can you please assist.
Kindest Regards,
Jeremy
Hey Ciaran,
I just sent the email.
Strangely is appears jQuery Easy is not working correctly with you extension. One option would be to try a different lightbox extensions. Alternatively we can replace ylur Javascript drondown menu with a CSS3 alternative. An example of which can be seen on our latest template (Habitat).
