1. Mol4
  4. Wednesday, 12 June 2019
On Goldcoast Fysio I'm using HTML in the J51 Layer Slideshow as you can see on the homepage (linebreaks amd orange button).
I've made a copy of this site where I tried to change the text. But when I save it the HTML gets stripped and is gone. I tried several things but nothing helps. Can you please have a look? Thanks!
Try replacing the following in ../modules/mod_j51layerslideshow/elements/slideshow.xml (line 4 & 5)...
<field name="j51_slidetitle" type="text" default="" label="Slide Title" description="Set your slide title" />
<field name="j51_slidecaption" type="textarea" default="" label="Slide Caption" description="Set your slide caption" />
With...
<field name="j51_slidetitle" filter ="raw" type="text" default="" label="Slide Title" description="Set your slide title" />
<field name="j51_slidecaption" filter ="raw" type="textarea" default="" label="Slide Caption" description="Set your slide caption" />
Thanks! This works fine.:D
To amend try using the CodeMirror editor when editing your module. Some WYSIWYG editors will strip HTML tags on save depending on editor settings.
Unfortunately this doesn't make any difference.
I tried it with Codemirror and without editor but this doesn't help.
Greetings Ton.
now the same problem appears in another testsite but now it affects the Icons Module.
Yesterday I used "<br />" in the Icon Title, today this is automatically removed when I save the module.
I also tried a solution JoomlaShack came up with, but this als didn't help.
Can it be a browser thing or the Joomla update?
Thanks!
Thanks! This works fine for the J51 Layerslideshow.
I also tried to achieve this for the J51 Icons extension but no luck here.
On which file (and line) I have to make the changes?
Thanks!
The XML for the title and caption field of each icon can be found at ../modules/mod_j51icons/field/item.xml (LINE 20 & 21). To amend add filter="raw" to each.
