1. George Sitaras
  3. Friday, 04 January 2013
Hi everybody,
My question is how can I use the typography codes?
I add this code in my article but with no results. The type of typography I was trying to use was:
Blockquote
<blockquote><p>Your list item goes here!</p></blockquote>
I upload two pictures, one the article editor and one the results.
Thank you in Advance
George Sitaras
Hi George
When using some elements of the typography it's best to first set your editor to CodeMirror as unlike the default editor this does not clean/edit your code when saving. To change your editor navigate to Site -> Global Configuration -> Default Editor -> CodeMirror.
I am one step before head stroke. I follow your guidelines and after Save Default Editor's change everything is full of some Strict Standards errors. I found that all these errors become from AcePoll module. I reinstalled it. The installation was successful but the error messages are still there. I send you a picture of AcePoll menu.
Please help me.
George Sitaras
Hi George
As I'm not familiar with the AcePoll module I would suggest contacting the extension developers.
In the mean time you could disable Error Reporting via your Global Configuration. From your Joomla administration navigate to Site -> Global Configuration -> Server -> Error Reporting.
Thank you Ciaran for your help.
I "cover" the problem but it is not solved.
I discover another problem, that my site has default language the English one despite that I have installed and make default Greek Language in administrator.
I made some uninstall/install procedures but with no result. I understand that this is not your criteria but if you have any suggestions where I should search for solution I will appreciate your help.
Is it so crucial to change between TinyMCA and CodeMirror editors?
Thank you Anyway.
George Sitaras
