1. Paulb2012
  3. Monday, 14 May 2012
The top menu on my Telsa template does not work on the home page. When you hover over it, the menu only highlights but does not pull down.
If you click on the menu, and go to the page, the pull down then works on that page. How do I get it to pull down on the home page?
Hi Paul2012
Your menu module may not be set up correctly, in particular setting the 'Always show sub menu items' to Yes within the modules parameters (Extensions -> Module Manager -> [YourMenuModule].
