1. n.hoeschel
  3. Wednesday, 25 September 2013
Dear all,
I get an error message on the thumbsgallery like you can see on the screenshot. Hope you have some suggestions. Thanks in advance.
@Norbert
Hi Ciarán,
Thanks a lot for your swift answer. It works perfectly!
Take care
@Norbert
Hi Norbert
Could you try installing the updated version of this extension which has been made at the following dropbox URL..
https://dl.dropboxusercontent.com/u/110280303/mod_j51thumbsgallery.zip
You can simply install this file via your extension manager to update.
