1. ilvaltere
  3. Thursday, 03 December 2020
I also bought the Layla template, which works well on the intranet. Unfortunately, however, I discovered that the Internet Explorer 11 browser is not supported (you need to use other Firefox Chrome Safari browsers) and this creates big problems for me because other government applications only work with Explorer and I cannot install other browsers on computers. I guess you can't easily solve the problem.
is there another template that also works with IE11 ??
could you recommend something?
thanks
Valter
Hi Valter
All templates released prior to 2020 will support IE11. In 2021, Microsoft will stop supporting IE11 which prompted us to no longer support it within our templates. The benefits of modern browser enhancments and the significant drop in IE11 usage also prompted our decision.
If you could mention a template that would suit your needs below, I would be happy to make it available to you in place of our Layla template.
thanks Ciaran
I tried the Evolution template, beautiful graphics and which partially meets my needs, except the "hornav" module, positioned above the "search" which always remains aligned to the right, while I would like it to the left so that I can better manage the numerous buttons that I will go to build ... but there seems to be no solution (see my other post)
if we found the solution to move "hornav" to the left, this template would also suit me
then I tried Layla, even better both for graphics and functions but unfortunately I discovered that it does not support IE11 (in the government office where the web server will work, the IE11 browser is used a lot (95%))
now i'm looking at Caitlin too ... but i don't understand if IE11 is supported
I await your kind answers
thank you and good evening
Valter
Hi Valter
Yes our Caitlin template is compatible with IE11.
I will look further into your query regarding the Evolution template.
