1. axman
  2. Pre-Sales Question
  3. Sunday, 01 April 2012
I purchased a template J51_Twilight the order Transaction ID: 7ME564287X658790B order number 11798.
I installed and I want it to be the same as you have it in the samples. but nothing is working Nivo-Szaki Slider is not working and also my side navigation and to navigation is not showing up. Can you please guide to correct the problem.
website address: http://184.154.225.8/~ceasarpr/ :sick:
Perhaps I need support from you guys...
May I suggest sending temporary adminstration access to your Joomla installation to [email protected] and we will set up some of the main elements of the template for you.
Ciarán,
I sent the email with the info.
Thanks,
Axel
Hi Axel
I have set up some of the elements of the template for you similar to that of our demo. When setting up modules for your template ensure their position matches does available to the template. For a diagram of the module positions for this template check out http://demo.joomla51.com/0066/index.php/module-positions
  3. # 3
Ciarán, Thank you so much for your help...
I like Joomla 51 templates, I will keep buying them..
Thanks,
Axel
  3. # 4
I just have a quick question regarding the logo size?
Can you please tell me where is CSS page and what line is it to change my logo size.
Thanks,
Axel
  3. # 5
Your logo is controlled with the following CSS (line126 - template.css)
[code type=css]h1.logo a {
background: url("../images/logo.png";) no-repeat scroll 0 0 transparent;
display: block;
height: 103px;
left: 0;
position: relative;
top: 0;
width: 100%;
z-index: 99994;
}[/code]
  3. # 6
Ciarán,
I did changed the logo size in (line126 - template.css) and it was overlapping with the hornav_bg,
the width for the logo is 358 and the height is 144.
Thanks,
Axel
  3. # 7
You can increase the space available above the 'hornav' position effectively moving your site content down by adding the following CSS to the end of your templates template.css editing 115px to your own taste..
#header {height:115px;}
You will also need to add the following to edit the social icons position.. for example if you add 50px to the above CSS you must also add it to the below figure.
ul#navigation {top: 67px;}
  3. # 8
Thank you so much for your help....
  3. # 9
