1. ilvaltere
  3. Monday, 03 May 2021
I bought the ELVIRA template and I am preparing the intranet site for the office (it is not connected to the public network).
I have built a lot but I would like to fix some more things, like the space occupied by the TOP1 module which consumes too much space in height, there is too much edge above and below that I would like to reduce.
Then it would also be necessary to customize the FOOTER which has the same problem, but here I would also like to change the color of the text font (now it is white ... not very visible)
how can I do ?
thank you, Valter (Italy)
Hi Valter
To amend the spacing around your footer-1 and footer-2 module positions, try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
(Edit to taste)
#footer-1 .module_surround {
padding-top: 20px;
padding-bottom: 20px;
#footer-2 .module_surround {
padding-top: 20px;
thanks for info. I looked in Module Style Overrides but I don't find the possibility to select the Footer module, I only find Top, Sidecol and Bottom
Hi Valter
Have you tried using the Module Style Overrides option within your template settings? Here you will have the option to editing spacing and color of each of your module positions. For further details check out .. https://joomla51.com/tutorials/template-parameters/module-style-overrides
