1. skwebyuks
  3. Monday, 24 February 2014
I am not sure which module i have to use for the bottom of slideshow?
which position and module for the text block "Nulla in enim quis
Lorem ipsum dolor sit amet, conse........." should I use?
also I am not sure what module and position for the images and info boxes below the text block?
I am still learning, could anyone advice me?
This is the article/component area of your template. Linking to an article, that article will appear in this area of the template.
For the images below the article area we used the ImageLinkHover module included with your download and placed it in to any of the bottom-1# module positions.
How do I achieve "article/component area of your template. Linking to an article, that article will appear in this area of the template.
I really don't know basics.
i created an article and how can I link to the home page's component area?
I am sorry to ask you again.
In Joomla to display an article you must first create a menu item linking to that article. From your Joomla administration navigate to Menus -> [YourMenu] -> New. In the 'Menu Item Type you can select 'Articles -> Single Article', selecting your article. On the same page set the 'Default Page' to yes to make this menu item your homepage.
I have managed to link an article to home page's component position, but i can't rid off the "getting started" the link after the slide show.
http://skwebyuks.byethost11.com/joomla3/index.php/homepage
where is that coming from and how can I red off?
This link appears to be inside your article? You can edit your article from within your 'Article Manager' (Articles -> Article Manager -> Getting Started).
the article is not "getting started" but it is a different article (NEVO) and the article doesn't contain the link, so i have not idea where the link is coming from. the original component's position had a "getting started" article was on, but i have repalced with the NEVO page.
That is strange. If you wish you can send temporary administration access to your Joomla installation to [email protected] and we will examine where this link is coming from. For our reference please paste a link to this post in your email.
Thank you. I will send it.
Since I sent the link and info. it has fixed somehow. so it is ok now, Thanks!
