1. jascanio
  4. Sunday, 12 May 2013
If I set a module to be displayed on position top-1f, but no other modules are assigned to any other top-1 position, is there any way to force module to be displayed on the right-hand side of the page?
thanks
regards,
juan
Hi Juan
One option would be to create a blank Custom HTML module for the top-1a position (Extensions -> Module Manager -> New -> Custom HTML). This will then force the top-1f to the right of the area. You can further control positioning using the 'Module Widths' option in your templates parameters.
ok,thanks for your reply
Regards,
Juan
