1. sammy1979
  3. Tuesday, 21 November 2017
Good morning, I bought your template J51 scarlett, it's all ok but I have a little issue:
I'd need that only one of the submenu in the "main menu" has two columns, it's possible modifying css? Can You help me?
I obtained the result of the image modifying css (I inserted "column-count: 2";) but this solution edits all the submenu
Could you post a URL to an example of your menu?
AT this moment, you can see the site at http://www.serconmarketing.it/caruter/
I would use a solution like https://www.consorziosea.it/ at the voice "comuni" in main menu
Admittedly I don't quite understand your query. You only want the 2 columns in one of the dropdowns? Adding columns-2 to the parent of that dropdown should achieve this for you.
It works perfectly! Thank you very much...It was simple but I did not think about it! :D
