1. bibbp
  4. Wednesday, 01 April 2015
Ciaran,
I am using the slideshow on the home page of http://www.bagcikids.com but I don't seam to be able to put the slideshow on the right side of an article with the text wrapped around it. I have tried changing the slideshowcontainer class and using float:right in a div. if I get it to go to the right (with a div) it collapses and the images dont appear. Any ideas?
I am using modulesanywhere from nonumber, perhaps there is another solution?
Pete
Hi Pete
Considering the size of your slideshow, it would not have room to float to the right of your text. Try reducing your slideshow width.
