1. cmobowmen
  3. Sunday, 19 March 2023
I can't get Eshop to display using the Stella template. Tried changing PHP version and made sure everything is up to date including Stella (although it still display v1.02 even though I have installed v1.03) but no luck.
I have also tried installing the jQuery fix plugin.
There seems to be console errors suggesting that the variable jarallax is missing.
Please can you help?
Martin
  1. https://sarahwaltonjewellery.co.uk/index.php/shop-menu
Hi Martin
Thank you Martin
Have you since been able to resolve this issue? When we check your shop we are presented with a notice from EShop stating "Our Shop is currently down for maintenance. Please check back again soon.".
Admitedly I am not very familiar with the component however it seems that the component is loading but offline?
Yes the issue was with the eShop and the language settings for the site not being setup correctly, and not template-related.
Thanks for your help.
Martin
