1. Humphrey
  3. Thursday, 07 February 2013
I have downloaded the Specialize Template twice. I have reloaded Joomla 259 twice. Tried everything. But the Template will not load properly. Please go to http://www.far-and-away-safaris.com and you will see what I get.
Hi Humphrey
Your template appears to be installed and working correctly however you don't appear to have any content in your Joomla installation. Joomla templates are simply how your content is viewed and can not in themselves contain any site content. If you wish you can send temporary administration access to your Joomla installation to [email protected] and we will set up some of the elements of your site similar to that of the template demo. You will need to have Joomlas 'sample data' first installed. An option to install the sample data is available when setting up your Joomla installation.
Thanks for your response. It still doesn't make sense to me. The menus are missing, most of the modules are missing ... Am sending Administrator access so you can see for yourself. :(
Forgot to add that I have used your J51 Resonate Template before. That loads perfectly.
Hi Humphrey
Our Resonate template includes a 'Demo Installer' which is a copy of Joomla with the template demo content included as the 'Sample Data'. I'm presuming this is what you used to creat your Joomla installation for your Resonate template?
There still doesn't appear to be any content in your Joomla installation, no modules, menus, articles etc. These have to be set up separatly to your template. You will need to have some content on your site for us to set up some of the basic elements of the template. An alternative solution would be to set us up with FTP access to your server and MyPHPAdmin access to your Joomla database and we will import the demo content to your site.
Sending it to [email protected]
Thanks!
