1. Martin Sund
  3. Friday, 26 April 2013
Hello and thank you for a large variety of beautiful templates!
Yesterday I purchased the Specialize template, and I have tried to set it up in a subfolder, on my existing website, just to be familiar with the template.
Find it here: http://www.photosolution.dk/fotosite
I have an issue.
1. When I activate the login module, the Autson and the Thumb Gallery module, either dissapears or act different as normal, depending on the JQuery setting in the Autson module. At the moment the JQuery is ON and Loading Method is set to onMod. (If OnLoad is used, the Auston gallery disappears) With this setting The Thumb Gallery modules is now open it's picture in an empty browser instead of in a nice popup-window. Can you help me with the correct settings?
Hi Martin
May I suggest replacing your slideshow with the J51-Slideshow available free to download at http://joomla51.com/extensions/j51-slideshow-light-responsive-slider
I did what you suggested, but it does'nt help much. if I enable the login module, the thumb gallery open it'a pictures up in an empty browser window instead of in a pop up window.
I have sent you my login infos by email, will you take a look at it for me?
best regards
Martin
Hi Martin
Could I ask you to resend your login details as we don't appear to have received them. Please paste a link to this post in your email for our reference.
I have just sent an email to your [email protected] mail
best regards
Martin
Thank you Martin
We have received your login details.
In trying to find a solution to your issue your server appears to be continually timing out. We will try again for you later.
Hello Ciarán,
I can see that you have been on my site... I will dissable the login module again, but next time you come in, you are welcome to activate it again!
Thank you for your help!
Hi Martin
The issue appears to be related to your Acymailing extension. Once the login module is enabled we are getting the following error from one of the javascripts from this extension...
TypeError: jQuery(...).tooltip is not a function
jQuery('.hasTooltip').tooltip({});
This appears to be effecting any scripts running after including that of the lightbox script of the ImageGallery which is also jQuery.
