Warning
JUser: :_load: Unable to load user with ID: 3463
JUser: :_load: Unable to load user with ID: 850
JUser: :_load: Unable to load user with ID: 751
JUser: :_load: Unable to load user with ID: 558
JUser: :_load: Unable to load user with ID: 553
JUser: :_load: Unable to load user with ID: 443
JUser: :_load: Unable to load user with ID: 304
  1. lorenzo
  3. Tuesday, 04 August 2015
I am building a site using the excellent classic template. Up until now all has been smooth and the small customisations I needed to make were fairly simple. But I have hit a problem and after hours of trying to fix it am no nearer a solution. Any help is much appreciated.
There is barely any space between the Read More link and the next article header. How can I create it? I have added a near empty ghost article and omitted the read more (should this be a button?) and the space seems okay. But I need the read more button to make the site look as I want it to. Does anyone have a solution?
Site
http://www.cardiolefrog.fr/
Hi Lorenzo
To resolve try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
.post {
margin-bottom: 30px;
Thank you Ciaran,
I tried this buit there is no change. The custom css now looks like this
/* Custom CSS */
.post {
Is there anything else I should be doing? Do I need to create overides in order for the custom css to work?
Hi Lorenzo
Just to confirm, you have added the suggested CSS to the Custom CSS field, not the custom.css file?
  3. # 3
er no. Sorry, i put it in the custom css.
What is the Custom CSS field?
Much thanks
  3. # 4
Many many thanks . I figured what the custom css field was and posted the code. Worked straightaway.
One more thing. On the demo the read more is a lovely blue button. All I have is a line of text. Is it pretty straight-forward to change this?
  3. # 5
Your Custom CSS field can be found by navigating to Extensions -> Template Manager -> [YourTemplateStyle] -> 'Custom CSS' tab.
  3. # 6
Great.. thank you for the update!
  3. # 7
adding
.post {
to costum-css does not work on your emani-template.
How to add mor space between articles there?
Thank you!
Mirko
  3. # 8
Hi Mirko
Would you have a URL to an example of the articles in question?
  3. # 9
https://homepagejoomla.live-website.com/index.php/aktuelles
Site is in progress ;o)
There are also the "Introductory images" in the blog, that i cant remove :o(
  3. # 10
(edit to taste)
.blog-items .blog-item {
margin-bottom: 3rem;
  3. # 11
ok, that works perfect! :o)
For the problem with the images you have no idea i guess?
will be a joomla-thing i guess.
Thank you for your help!!!! :o)
  3. # 12
