1. Michal
  3. Sunday, 13 June 2021
I just installed Sophia and I would like to use News module.
The problem is that:
  1. When I change the layout in Administration then no changes are applied
  2. Hover effect is not active Title
  3. Maybe not connected to this issue, maybe yes, but my installation throw this error in console "Uncaught ReferenceError: Modernizr is not defined". Tried to put link to the modernizr manually to top od HEAD, but there was no effect.
Website
Thank you for your help, Michal
Hi, not sure how, but points nr.1 and nr.2 are fixed now. Maybe some caching issue, not sure :(
Hi Michal
Does adding the following to the Custom Code -> Head Custom Code field of your template style settings resolved the issue?
<script src="/https://cdnjs.cloudflare.com/ajax/libs/modernizr/2.8.3/modernizr.js" integrity="sha512-lOtDAY9KMT1WH9Fx6JSuZLHxjC8wmIBxsNFL6gJPaG7sLIVoSO9yCraWOwqLLX+txsOw0h2cHvcUJlJPvMlotw==" crossorigin="anonymous" referrerpolicy="no-referrer"></script>
Hi Cirian, unfurtunatelly yes. I added you code with small fix (after src= you have backslash), but the result is the same. You can check it live, I will keep the line in Head Custom Code
Thank you for the update.
Thank you Ciaran, good support :)
