1. herszbaum
  3. Tuesday, 11 July 2023
I recently upgraded from Enterprise for J3 to J4 and then social media icons are missing both on the frontend and also the backend in Template - Styling.
thank you!
Thank you for the prompt update. For some reason the update did not load. I received the following error messages:
JInstaller: :Install: Can't find XML setup file.
Unable to detect manifest file.
Any idea why that is?
Thanks,
Nestor
I was able to install the update to Enterprise. A soon as I added the social links to the backend the front end stopped working and got this message:
0 - json_decode(): Argument #1 ($json) must be of type string, array given
I turned off many extensions to see if that would bring back the frontend, but it didn't.
I sent the backend login information to the above email.
thank you!
We do not appear to have received login details related to this post. Could I ask you to resend these details to [email protected], ensuring to include a URL to this post for our reference.
As we do not have access to your Extensions Manager, could I ask you to redownload your template and install it to your Joomla installation. We have just created an update which should resolve the json_decode error for you.
I just notice you have since given access to your Extensions Manager. I have installed the update and your site is now loading correctly.
Ciarán,
Thank you very much for the template update!
I found a few issues before I'm able to publish my website:
1. There is a debug bar at the bottom of the frontend, even though I'm not logged in (screen capture below)
2. I receive a warning message in the backend about an override to check for blog.php (screen capture below)
3. A minor issue is that all <hr /> have disappeared. The tag is present, but not the image
4. I've also noticed that typo.css, where the hr style used to be located for joomla3, doesn't load anymore. I wonder if that style is located elsewhere now.
Thank you,
Nestor
Please ignore the debug bar part. I forgot that I turned it on when the frontend was not working...
2. For the override check simply select and mark as checked.
3. Thank you for reporting this issue. I have just created an update for this template which should resolve this issue for you.
4. For the Joomla 4 version of the template, the typo.css has been merged in to the nexus.css to reduce server calls.
Thank you so much Ciarán!
