1. marben
  3. Saturday, 15 April 2023
When positioning modules in the TOP-2 positions, an incorrect display occurs - for example, a single module is not displayed across the entire width, when three modules are used, the display collapses. TOP-1 and TOP-3 positions are displayed correctly.
Would you have a URL to an example of this issue? Ensure to check the settings in your template styles Module Widths tab as you may have the auto width disabled and set manual widths for these positions instead. This can often happen if you started with the template demo.
