1. Mol4
  4. Wednesday, 29 November 2017
Hello Ciarán,
Sorry to bother you again with this (https://www.joomla51.com/forum/sidecolumn-position-on-mobile-after-component).
On my clients website on mobile view the sidebar module is visible above the maincontent. When clicking on the screen or scrolling down the module 'jumps' to the bottom.
Maybe you have another suggestion to fix this?
Thanks!
Ton
Hello Ciarán,
thanks you, this works!
Greetings,
Ton
Hi Ton
The solution to this would vary slightly depending on your template. May I ask what template are you using?
Hello Ciarán,
The template I'm using here is J51_Stockholm.
Thanks!
#main {
display: flex;
flex-direction: column;
#sidecol_a, #sidecol_b, .sidecol_a, .sidecol_b {
order: 1;
