1. Samma
  3. Wednesday, 27 August 2014
Hi Ciarán
Thanks so much for your help so far, has been amazing!
I'm in the process of building a learning resource and require a side column menu which has already been created. However, because of the many many categories and sections, I'd like to make the list much shorter (into a grid or table) and then also use a java-slider for the main sections.
Is there a way to do this with your 51_Executive template?
Samma
Hi Samma
Sorry to this this would not be possible via the template alone however you may be able to find a menu extension which will add this feature to Joomla for you... http://extensions.joomla.org/extensions/structure-a-navigation/menu-systems
