I have encountered a problem displaying a multipage pdf especially in IOS devices.  Only the first page is visible.
I have two ways to display it correctly.  On a mobile device I would hjave available a url link to point to the pdf stored in /image and let the viewer click to view.
For other devices I can put a line of code starting <object> with details of the file location and size and media type etc which works fine. This feature is inbuilt into TinyMCE for Joomla 4.  FYI JCE offers a different solution creating an iframe to show the pdf.
I would like to write some conditional code that will select which line of code runs when somebody visits this particular Article in Jooomla.
I understand it is not reliable to determine the device in use so would have to rely on a certain breakpoint on screen size.
Have you some guidance you could share please on how to insert some code to do this (I realise this is not strictly a template issue but hope in this case you may be kind enough to give me a start in doing this)
many thanks!
			- DeltaJ59
- Friday, 10 March 2023
