1. [email protected]
  3. Friday, 10 February 2023
Hello Ciaran, I use the template Serenity Joomla4, unfortunately the mobile menu is not displayed to me. If you click on the upper right part of the page where the mobile menu should be, the menu appears. Can you help me here? Thank you and greetings, Sandra
Attachments (4)
Hi Sandra
Have the same problem!
What is the solution?
Edit to taste where white is the color of the menu toggle
body {
--mobile-menu-toggle: white;
Perfect, it works, thanks Ciaran for the quick help and have a good week. Sandra
Unfortunately too late! It annoyed me and I switched to another template.
Hello Ciaran, I have a new problem.
The modules bottom-1 and bottom-2 react differently than bottom-3. I have specified the size with 30% for the modules 1a,2a,3a and inserted images there. When I reduce the size of the page, the size remains the same for bottom-3a in proportion, for 1a and 2a the positions are wrapped and thus the images are enlarged. I would like them to remain 30% in proportion to the page and the positions a and b to be displayed next to each other and not under each other.
The access for you is still active. It is about the menu "Plant colors", this is also an extra template "Serenety Pflanzenfarben" assigned.
Thanks for your help
Kind regards
Sandra
Hi Sandra
Would you have a URL directly to an example of this issue?
Here the URL https://coiffurematilde.ch/test/pflanzenfarben
Sandra
Thank you Sandra
.bottom-3 {
width:100% !important;
To display the bottom-1 and bottom-2 modules the same as bottom-3, you can add the following custom CSS instead..
.bottom-1a,
.bottom-2a {
width: 30% !important;
.bottom-1b,
.bottom-2b {
width: 65% !important;
???Many thanks Ciaran, have a nice week. Sandra
