MENU
  1. EFH
  4. Thursday, 29 October 2020
Hi there,
Good old Google has detected some Mobile usability issues and I am wondering whether you can help fix the issues.
Text too small to read
Clickable elements too close together
Content wider than screen
website: http://www.justweddingentertainment.com.au
Thanks in advance!
Hello EFH,
I also got the first 2 notifications on several of my sites and I solved that by setting the module mod_J51Layerslideshow (or mod_J51Slideshow, look for the correct name in your admin panel) in robots.txt to "allow". The cause could be the navigation buttons of the slider.
I don't know if this can help in your situation, and you may need to test this procedure with other modules as well.
So:
Allow: /modules/mod_j51layerslideshow/
Allow: /modules/mod_j51slideshow/
The other message "content wider than screen" is unknown to me.
