1. mikestam689
  3. Thursday, 05 January 2023
I have recently installed the Riley template and created a menu with submenus. I have set the "Mobile Menu Close on Event" option to "No" in "Responsive Options", but the menu still closes when I try to open a submenu on my mobile phone.
After digging a bit in the code, I believe the problem is the following: in
scripts.js
, line 79, there is the following condition:
if(templateOptions.mobileMenuCloseOnEvent)
. The value of
at runtime is 0 as intended, but the type of the variable is string, and therefore the condition becomes true and the pertinent event-listener is added, so that the menu closes on mouseup.
Can you please check this and suggest a good fix? I've implemented a solution on my site but I wanted to check with you in case you are planning to fix this with an update to the template.
Many thanks!
Mike
Hi Mike
Thank you for bringing this issue to our attention and for the detailed explanation
I have just created an update for this template to resolve the issue.
Kind regards
