1. joan
  4. Friday, 21 November 2014
I browsed a lot of topics , can not find the solution.
J51_Letterpress / gtwf.nl
The items of sub menus do not show in the responsive menu (Mac OS / Android) , when the site go to low resolutions.
After going to one of the sub menu pages (direct link) the sub menu's (arrows) Appear?
Please advice?
Hi Joan
Thank you Joan
The 'Content iDeal' plugin appears to have been causing this issue. Disabling this plugin has resolved the problem.
It may be worth considering installing the 'jQuery Easy' Joomla plugin (http://extensions.joomla.org/extensions/core-enhancements/performance/jquery-scripts/18327). This is a great tool for working around any Javascript conflicts.
Ciarán,
Thanks you for your quick and helpfull response.
Problem solved! :)
Cheers Joan
