MENU
  1. zatharis42
  3. Friday, 27 February 2015
Using Cashmere, I have found that top level links that have sub items on the main menu do not work when the menu switches to "Mobile" view (or narrower than 720px in the case of my site). For instance, if one views the site in responsive view with the mobile friendly generated menu, any links form the main menu hat have submenu items simply toggle the view of the sub items on and off. Go back to normal view and the link works as expected. what is odd is that when one rolls over the link the correct hyperlink is displayed at the bottom of the window (in Chrome) AND once can right click and "copy the hyperlink" so the link is actually there but inaccessible by just a simple click on the menu item.
Any thoughts on how to make this work as it should?
The site can be viewed at http://www.historicwynnewood.org
May I suggest the following post which, presuming I understand you correctly should resolve the issue you are having.. http://www.joomla51.com/forum/8-commercial-templates/5991-enlighten-mobile-main-menu-not-fully-functional#13254
