1. bruno56
  3. Sunday, 10 May 2020
Hi, I have problem to maintain responsive behaviour in Bianca Template.
I tried all the possible setting but if I set onepage template as default and set onepage menu I loose resposnive and also if I go back to default template no more responsive is set.
I noted in the template configuration that the first selector for responsive is missing
Please help
Thansk
Bruno
  1. http://chamiandco.ethnet.it
Thank you!
Bruno
Hi Bruno
Hi, Yes, here it is
http://chamiandco.com/ONEPAGE/administrator
user: removed
password: removed
Bruno
Thank you Bruno
In case I use again Bianca, may I know
where I was wrong?
Bruno
Hi Bruno
This was a template related issue so nothing you did was wrong. We have applied a fix for the error to the latest download of the template.
