1. b4studio
  3. Monday, 31 October 2022
elp! I'm unable to find what code will work to create responsive grid layouts within articles. Please advise.
Here are two example layouts that I use with other templates, but that DO NOT work with J51 Nina Template:
<div class="row-fluid">
<div class="span4">...</div>
<div class="span8">...</div>
</div>
or something like this:
<div class="container">
<div class="row">
<div class="col-sm">One of three columns</div>
</div>
</div>
Presuming you are using Joomla 4, you could try using the Bootstrap grid syntax as demonstrated here as Joomla 4 is built on Bootstrap 5... https://getbootstrap.com/docs/5.2/layout/grid/
This isn't working. I'm using the J51 Nina Template for Joomla 3. Help!
If using Joomla 3, have you tried the columns option details at the end of https://www.joomla51.com/demo/0173/index.php/features/typography ? Would you have a URL to an example of where your initially suggest code does not work?
