I suspect you are correct. The URL displaying the issue appears to wrap your site in a frameset. This can been seen if you look at the website source. Have you tried contacting your hosting provider on this issue?
I inform you that the masking of the URL that fixes it on http: //http://www.dominioredirect.extensione happens through Frame (does not responsive).
The masking depends on the programming of the destination site. There are methodologies that do not support loading in a frame.
To solve the problem, in this case, it must then set the destination URL as visible and not as hidden."
I solved not making visible destination url.
Hello and thanks
