1. WEBcatch
  3. Friday, 08 November 2013
I am making a site and I have some problems with popups.
They don't seem to work?
When I posted this on the Joomla Forum, they found some discrepancies.
http://forum.joomlanl.nl/media/kunena/attachments/1042/Yndi20131107-466.png
Can you help me to solve them?
An example of the products in VM where the popup doesn't work:
http://www.r-q.nu/portaal/nl-NL/ophangsystemen-schilderijen-2/newly-r10-wandrail-200cm-wit-maximale-draagkracht-20kg-m-detail
We updated your template to the latest version which has amended all errors on the template however there still appears to be an error coming from the virtuemart lightbox...
TypeError: jQuery(...).fancybox is not a function
"transitionOut" : "elastic"
Should I post this problem on the Joomla forum?
Before you do could I ask you to try enabling a default Joomla template (protostar) and see if the issue is still present?
I switched to Atomic and the problem is still not completely solved. When I switched to this template, I could change the pictures but they still did not pop up.
So does that mean that the problem is in Virtuemart?
Protostar is the default for Joomla 3.0
I am sorry to say this would indicate the issue is not template related. Have you installed any plugins to your site that may be clashing with your Virtuemart popups?
I have installed some plugins. I tried disabeling some of them, but it still does not work. I am going to post my problem at the Joomla forum, I guess it is Virtuemart related.
I posted my problem on the JOomla NL forum and they found one existing error. A template error ...
They also gave me a link to the Virtuemart forum:
http://forum.virtuemart.net/index.php?topic=112582.0
However there are so many pictures in this site, is there another way to solve my problem?
Sorry for the delay.. I somehow am only after noticing your reply.
Could I ask you to resend your Joomla admninistration access details and I will take another look ([email protected]). please paste a link to this post in your email.
I have installed and set up the 'jQuery Easy' plugin and all appears to be now working correctly.
