1. skyd34th
  3. Monday, 18 August 2014
I want to use language selector in horizontal mode, but in this template this not work
and also want to change search to module position and put there language selector
Link
can you please help?
best regards
.lang-inline li a {
background: none repeat scroll 0 0 rgba(0, 0, 0, 0);
display: inline-block;
padding: 0;
.mod-languages ul li {
padding: 4px 2px;
For the search field may I suggest the following tutorial... http://www.joomla51.com/tutorials/item/converting-the-search-field-to-a-module-position
Great, thx
