1. WMWRick
  3. Tuesday, 17 September 2013
Hi All,
I've been developing a J51 - Resonate template on a local dev server however when I load the site in IE the top menu displays for a second or so and then fades away. Works fine in FireFox, Chrome, etc... It sort of looks like the slide show is loading over the top of the menu / logo area.
I've uploaded a screen shot of the fade just after the page loads and a second showing no top menu.
Any ideas on how to fix this?
Cheers,
Rick...
Hi Rick
In what version of IE are you having this issue?
As always thanks for your quick response!
It looks like the main issue is with IE9 Compatibility View but IE7 is having trouble too...
IE7 = Not displaying
IE8 = OK
IE9 = OK
IE9 Compatibility View = Not displaying
Cheers,
Rick...
Hi RIck
Is there any chance we can have access to a live version of your site as we are unable to replicate the issue you are having in your screenshots (template does not support IE7).
I'm working on uploading to a live server as we speak and will PM you the staging address as soon as complete.
However, in IE9 Compatibility mode the issue is evident on your live demo site (see attached screenshot).
Thanks again for the quick response!
Cheers,
Rick...
Hi RIck
#container_header .wrapper960 {
position: relative;
#header {
position: relative;
z-index:20;
Perfect Ciaran - all fixed!
