1. Okel
  3. Friday, 18 December 2015
Together with my brother-in-law I am builing a website for my girlfriend and have have some question which I will raise seperately.
The first one is the resize of some modules in the Enterprise template.
Is it possible to resize the height of the Top and Base modules. I have already succeed in the resize of the height of the header, but these modules not yet.
Thank you for your advice,
Edwin
Hi Edwin
By default modules will resize to contain its content. If you wish you can set a height to each row of modules suing some Custom CSS. Would you have a URL to an example of your modules and I can supply you with the CSS needed to resize?
Ciaran,
The website is http://www.okel.nl
Enjoy the holidays,
Edwin
Hi Edwin
On which modules would you like to set a specific height?
The modules I would like to adjust are:
J51_icons on the top-1a position
base-2 positions with the website info, contact, newletter etc.
Best regards,
Edwin
Hi Edwin
You best option would be to firstly set the 'Remove Container Padding' to yes ('Module Widths' tab - template parameters - top-1). You can then edit the height via the vertical margin field within your icon modules parameters.
