1. webknecht
  4. Friday, 23 October 2015
I used the showcase position not for the slideshow but for a modul which shows one picture there. It works fine but now I try to eliminate the vertical gap after the image!
Here you find the URL: http://www.trulli-ramstein.com/index.php/en/menue/pasta-and-more
Maybe there is a smart solution for this issue???
Thanks in advance
Juergen
Hi Juergen
To resolve try adding the following to the Custom CSS field of your templates parameters...
.showcase p {
margin-bottom: 0;
thanks a lot, it works fine!
Juergen
