1. ziggy
  4. Saturday, 29 August 2015
Hi, can I ask some question for the renovate templates?
-in the mobile versione I don't see the text in the Position: [ Style: none outline] (attachement 2 and 3)
- how can I place the icons ? those who were initially in place top - 1b (attachement 5)
- in the mobile version , there are too many space between words (attachement 1)
link dirittoedanno.it
thanks
giuseppe
These positions are usually optioned in your templates parameters to enable/disable. The positions labeled are available by disabling either of the top/footer menus (Template Parametera).
The icons are created using the J51 Icons module. An install file for this module is available with your template download.
Your text appears to be set to justify which will cause large spaces on smaller screen devices (general issue - not template related). Try aligning your text to left to avoid this issue.
I found the module icons : j51_icon , I saw the code - icon fa-coffee , but icono not appear .... - > see dirittoedanno.it in the position top - 1b
and it is possible to insert a link exsternal and not internal? I want to link a http://www.google.com, but I see whene I insert the link it open inside the website...
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will install the module for you. For our reference please paste a link to this post in your ema
