1. jeffreybrock
  3. Wednesday, 02 April 2014
I seem to be having an issue with 4 Custom HTML modules. Top 1A and Top 1B are good, however, 1C, 1D, 1E and 1F drop down to another line. Can not figure out what is going on with it. Any suggestions?
I sent you login details via email with URL
thxs
Hi Jeffrey
It sounds like you may have manual widths turned on in your templates parameters and that these widths total more than 100% causing your modules to float to a second line. For further details on the manual widths option of your template may I suggest the following... http://www.joomla51.com/tutorials/item/understanding-the-module-widths-options
